Discuss sequence of how the electrics of a s plan Work in order from the programmer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
Can someone explain how an s plan heating system work from the sequences through the eletrics. So if I call for heating from the programmer it will send a signal to the room stat and so on and so forth...
L N E In
time controller /prog sends to
(heating)
room stat (calling) , which sends to
zone valve
zone vale opens (and opening micro switch)
fires boiler and pump
L N E In
(hot water)
Cylinder stat (calling) which sends to zone valve
zone valve
Something like that. We have to memorise the wiring diagram for a s plan system.
get your books out, have a look at the diagram in there, memorise it then draw it out a few times fm memory, do it enough and you'll never have to ask on here again.
+1 or do test benches
and get someone to move wires about
Reply to sequence of how the electrics of a s plan Work in order from the programmer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached picture from their catalogue. Like on this image ->...
Sebastian T
