Discuss sequence of how the electrics of a s plan Work in order from the programmer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
Can someone explain how an s plan heating system work from the sequences through the eletrics. So if I call for heating from the programmer it will send a signal to the room stat and so on and so forth...
L N E In
time controller /prog sends to
(heating)
room stat (calling) , which sends to
zone valve
zone vale opens (and opening micro switch)
fires boiler and pump
L N E In
(hot water)
Cylinder stat (calling) which sends to zone valve
zone valve
Something like that. We have to memorise the wiring diagram for a s plan system.
get your books out, have a look at the diagram in there, memorise it then draw it out a few times fm memory, do it enough and you'll never have to ask on here again.
+1 or do test benches
and get someone to move wires about
Reply to sequence of how the electrics of a s plan Work in order from the programmer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
Customer complains of Intermittent heating on Y plan with Stat satisfied. New boiler fitted last year (no permanent live required or fitted...
2K
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
