Discuss Services per week. (on average) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
GrahamM
One for the service guys/gals here.
On average how many annual services do you do a 40hr week. Looking for a general balance so asked per week instead of per day, as I know some days you may be hit with 3 or 4 BBU's.
The story is a mate has just been offered a job and they are looking for 50 per week. Private housing as far as I am aware. He says if he doesn't meet the quota they will take it off wages. He will be on an hourly rate (that isn't great) that will be reduced based on numbers. I was doing mostly social housing and with the odd BBU and no-access I was pushing it to hit the 40's some weeks.
50 a week is a tough one, at the end of the day you're signing it off.
It might be possible if FGA-ing everyboiler, but it's got to be a bare minimum quality job.
Bosses might say they'll back you up, but when it goes to Health & Safety, It's all about you !!
Also if you come across a fault it would throw the target out.
I've being servicing for 30 years plus & believe it should be quality rather than quantity.
Sometimes needs must, but protect yourself.
Good luck
Reply to Services per week. (on average) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I hope someone here has the expertise to help. I know exactly what situation it took awhile. On the loft on the 6th floor there is a cold water tank this tank feeds six properties in a straight line below my property is on the third floor so in the middle. The job would entail...
I wonder if anyone has any thoughts? Combi Logic 30 Boiler - constant pressure loss - no obvious leaking. Few years ago we got an error code indicating pressure was below minimum. We resolved ourselves by using the manual and topping up per the guide. Sometime later, in some really cold...
1K
Hi guys So basically what happened is an engineer came out to my mums a week ago to do her annual gas safety check, shes a disabled bed bound OAP so on these occassions i have to go to the property to let the engineer in to do the job, she lives in a council property in London. So guy turns up...
3K
Hi all This is only about my third/fourth post, so go easy. Also, I'm only an enthusiastic amateur, not a pro... I'm having issues with the waterboard and can't work out what's happening. For the past three months, they're saying we're using a huge quantity of water - 700 litres per day at...
2K
Hello, I hope I post this in the right section. I bought a house couple of months ago. There was an old, broken back boiler installed in the fireplace, so I looked for a company to replace it with a nice shiny combi boiler. A gentleman came over to estimate the work. He offered to replace the...
2K
