Discuss Sewer inspection shaft in the USA area at PlumbersForums.net
Hi
Can I extend my 100mm sewer inspection shaft up through new slab for shed?
From a technical perspective, I cannot see why not. You may need to check local legislation to see if this needs to be approved by, or notified to, the authorities.
Reply to Sewer inspection shaft in the USA area at PlumbersForums.net
