Discuss Shared Soil Pipe Help Please!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
AlixGreen
I live in a mid terrace house and my neighbor and i already share a soil pipe we have one toilet each on it currently. It quickly disappears into my neighbors leaving me only a small section and a bend. I would like to add another toilet onto this soil pipe. Are there any legal reasons why i cannot do this and are there any complications likely to happen if i do do this?
I am a bit confused please help!
Just speak to your neighbour and explain what you plan to do, can't see them objecting but always best to explain before carrying out any work.
Reply to Shared Soil Pipe Help Please!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
We have a problem with a downstairs bathroom toilet. When flushed, the water in the bowl rises, as does the water coming up from the shower drain...
Hi guys, I've had a search and couldn't find anything related. Installing a wall mounted toilet, unfortunately didn't know this when I put the...
I'm a DIYer and have a problematic toilet setup to fix: The waste pipe was installed too high for waste to flow out from a standard toilet...
Had a collapsed/cracked collar on the 90deg angled piece that my soil pipe sits in which is leaking water so has needed replacing. Access has...
