Discuss Should the pipe from the top of the Water Cylinder be hot rather than warm in the USA area at PlumbersForums.net
Hi all, I have a Megaflo Heatrae Sadia running from a conventionla boiler. The boiler is 12 months old, the cylinder about 6 years old.
The cylinder has two separate pipes in at the bottom left, both of which are too hot to hold for more than a second. There is a stone cold pipe going in the bottom at the front and the one with the drop inspection thing at the front centre which is also cold.
Out of the top, is, what I presume the feed to the hot taps and that is only warm and I can hold on to it absolutely fine.
My hot taps periodically only run luke warm even when the hot water has been on for over an hour before.
I tried to turn the immersion heater on for around 25 mins and felt the pipe at the top again and it is still luke warm.
I've taken the grey panel off the front and the red dial is set to 4 out of 5 so presume that is correct.
Big question - Could someone please confirm whether that top pipe should be almost as hot as the scalding ones going in or at least too hot to hold for say 5 seconds?
If so, my first guess is a new thermostat for the cylinder which I think can be done without draining the tank?
Any help on the above would be appreciated.
Many thanks in advance
John
Post some pictures please which top pipe are you referring to ?? Kop
Hi KOP, thanks for looking, pictures below
Its all correct bud the luke warm top pipe should get hot when hot water is used , the low two are from the boiler and should be hot when theres a hot water call to reheat the cylinder, cold pipe is drain for the safety valves , ice cold one is the mains cold water in to the cylinder , check your programmer for reheat times . Kop
Thanks KOP. Will run a hot tap and see if it is gets any hotter. Runs off Hive and had definitely been on for hours.
Is this valve open there's a small lever that should feel free to move if it's open , if you feel resistance then its closed ?
Definitely would go as far as saying its floppy, if a mechanism in valve is due to move it at some point I think it may struggle with stiffness so that could be the first thing to try replacing đź‘Ť
Just experimented and it moves from left to right when hot water turned off, but then when you turn it on, it doesn't move back again and it does seem to be getting stuck on that right hand side where it is much stiffer, so I think even though it is pretty new it is that valve which has gone
Thanks for all your help KOP đź‘Ťđź‘Ťđź‘Ť
Hi KOP, thanks for looking, pictures below View attachment 60610View attachment 60611
Even though the two coil heating pipes are "roasting", might be no harm to check the position of the manual valve with the red handwheel, it should take ~ 4 to 5 full turns to open or shut it, shut it fully, then reopen it fully, shut it fully (again) then reopen it ~ 1 to 2 full turns or if it was fully open originally return it to this position, the coil should heat the cylinder, depending on its volume, in 15 to 45 minutes so 1 hour should definitely heat it except programme time too short or cylinder stat set too low or faulty. If heating it with one electric immersion can take a few hours, depending on cylinder volume.
Thank you John, will give that a try as well đź‘Ť
Reply to Should the pipe from the top of the Water Cylinder be hot rather than warm in the USA area at PlumbersForums.net
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
About 5 year ago, I had a new central heating system (radiators) installed to replace my old warm air underfloor system. The warm air side of the...
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
hello we have an unvented system. we have an issue where the hot water is hot for 10 seconds and then luke warm, turn off taps / wait and turn...
