Discuss Shower Leaking into the kitchen in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We moved to a new house a few months ago and recently the ensuite shower started leaking into the kitchen. My husband had started to take away the sealant and noticed that the shower tray is not flush with the tiles, so that's likely to be where the problem is but obviously need to ensure that's the only area as there two areas of staining on the kitchen ceiling. My Father has told me that you are meant to fit a shower tray and then tile, not the other way around and we will continue to have leaks unless this is rectified. I do not really want to start looking at re-tiling though and was already considering getting an electric shower fitted as currently there's an electric pump in an upstairs cupboard which gives the shower it's water pressure but it's temperamental and sometimes doesn't work. So wondered what your thoughts were of fitting an electric shower and new shower tray and shower doors, I have attached photos of the current shower, pump and enclosure and what I thought of replacing the enclosure with and also having and electric shower fitted, as the suggested enclosure has a low tray (there may be more ultra thin corner trays available?) would the tiles still need to be disc cut and then the tray inserted?
On another note the main bathroom for some reason the previous owners installed a new bathroom without any extraction fan. I have attached a photo of the bathroom and the light fitting and was wondering whether the light fitting can be changed for an extraction light fitting (as we have one in the ensuite) and then it possibly be fitted up to the other extraction and out of the house?
It looks like a lovely bathroom. Ideally the tiles should sit on the shower tray but not essential, re seal with sealant making sure it is squirted in to the gap as well as on top and finish with a sealant tool, my daughter's bathroom had the tiles behind the shower tray and I had no problem sealing but check and resell every six months or so, it only takes about an hour to scrape out and resell.I would definitely not change to an electric shower, the flow rate is nowhere near as good and they don't look that good. You will not need new shower tray and doors.I may be wrong but if the bathroom has a window that can be opened I don't think you have to have an extract. My bathroom is quite large and if it gets too steamy we just open the window for a couple of minutes. The problem with extracts that are linked to the light switch is they are extracting heat when you don't want them to.Shower pumps normally work or don't so I don't know what the problem is there but a new pump would cost a lot less than all the other things you were suggesting. I hope this helps.
You could fit a tile to tray trim like Byretech Showerseal 4 Sided Ultra 10 White - 1.25m - SSWK02 | B-TECH-SSWK02
Before doing so remove the old silicone and re-point the gap flush with silicone, let it set, then fit the trim kit.
As to the shower I would definitely keep what you've got (see if you can get the pump repaired or replace). Electric showers are never as good as a mixer shower IMO.
Cheers
Wouldn’t install the trims. Never came across any trim which was done right. They always leak and leave horrible marks. As KOP said, re sealing would the job.
Yes plastic trims are awful, this could be a case for the classic Johnson Cristal ceramic bath quadrant trims! Silicone seal joint to do the actual sealing then cover with these 70’s beauties. If done well they look good, cover a big gap and clean up nicely....honest
Not with that lovely modern bathroom methinks!!!
Yes you are right, I only looked at the shower pump on the attached photos and assumed the main pictures were their bathroom.Why would you enclose brochure photos?
Actually I think I can answer my own question, on reading the original post more carefully she referred to these as something she might change to. Silly me I will slap my own hands, I thought it was an incredibly sleek, clean bathroom!
Apologies was only trying to be helpful, I don't like trims myself. Good quality sanitary silicone and use Elch or Fugi tools and or course Wonder Wipes or similar to clean up with as you go!
A good clean up and reseal should sort the problem out done alot worse than that, I do maintenance in a hotel the baths are always moving due to being poorly installed in the first place not had one beat me yet best of KOP.
Evening KOP,
Can I ask you what you find best to clean old sealant/silicone off with, after the Stanley knife blade, fore finger and thumb nails (or what's left of them of course :D) ?
Cheerz
Evening KOP,
Cheerz
screwfixs own silicon cleaner for me
Looking at the images of the gap, I noticed the original installer hadn't even taken the plastic off the bath.
The first thing I would do is chemically clean the space where the new silicone is going. So, using something like isopropyl alcohol I'd make sure the bottom edge of the tiles is spotless and then also clean every trace of silicone off it and clean with the IPA again.
I'd then put in a support under the bath edge to make sure it cant drop again.
Then, I'd do as KOP would and reseal getting it right in and under and finishing properly.
No easy way jim usually a stanley knife and also the ones with the snap off blades for more reach , scrapers various sorts , tried the paint on silicone removers but not great they do soften it to a point , plenty of industrial wipes and blue roll and elbow grease really mate . Cheers kop
Yes I agree, no easy way and no short cuts. That’s why my heart literally drops 3” inside me when the dreaded phrase “while you’re here could you just re-seal the bath” - they think it’s a five minute job whereas in reality it isn’t.
If one could formulate something to actually remove old silicone there’s a fortune to be made, and us plumbers will love you forever.
Vicdiy, your user name says a lot, just about every point in your reply is diy.
ie Check and reseal every six months? Are you for real? :mad::mad::mad:
[QUOTE
If one could formulate something to actually remove old silicone there’s a fortune to be made, and us plumbers will love you forever.[/QUOTE]
There are, some work better than others.
Vic. Everyone is welcome on here, however may I suggest you proceed very carefully with regard to offering contradictory 'advice' to that from the boys and girls on here who make their livings from it.
Your, lets be polite, 'incomplete' knowledge is leading you to proffer an opinion which would lead a homeowner to do something illegal. This is just one small step from dangerous.
No
professional can countenance your DIY approach. Customers pay us for our knowledge & professionalism - a fix, not a suck it and see bodge for 6 months.
I appreciate everyone's comments back and have decided to keep the original shower as per suggestions, I might need to change the pump though as its temperamental. I do really want to have a long term fix to the problem leak though and not have to reseal every 6 months whilst keeping my fingers crossed that water isn't slowly leaking somewhere without me knowing. I think to do this though the shower tray will need to come out, the bottom tiles taking off and then the tray being refitted and then the tiling done onto the tray. I don't know though how to get the tray and trap out though, any suggestions?
I really think that if you have to ask this, the chances of you ending up with a leakfree shower are slim. Best to get someone competent in to do it, shouldn't cost too much and won't leak.
I am happy to get someone in, just want to understand what's involved, I also appreciate that a lot of plumbers probably don't want to get involved with taking off tiles and retiling etc and just want to do the plumbing part, so we may have to do this.
Sarah,
The resealing every 6 months is incorrect advice, may be every few years.
If you employ a competent person and they use a good quality sanitary silicone you really won't have any further issues. Your suggestion as to removing the tray and bottom row of tiles, however it's a big job. It involves removing and re-fitting/sealing the cubicle and will affect your flooring to a certain degree (what flooring do you have.
ATB
Sarah,
ATB
I appreciate that it's a much bigger job to remove tray and refit it, but the tray isn't flush with the wall and the gap is quite large, so I would be worried that once it was resealed that water would be slowly getting into that gap. So I want peace of mind and although it will mean more work, I think in the long term it will be for the better. There are tiles on the bathroom floor.
It's your call, that's fine.
From your pic https://www.ukplumbersforums.co.uk/attachments/current-shower-and-tray-jpg.34738/ it looks like the trap can be unscrewed from the top, often there is a special tool that comes with the trap. You may be able to unscrew it by hand.
As mentioned the seal to the cubicle will have to be cut, at the wall and at the tray. Dismantle the cubicle in as few pieces as practicable. Cut out the bottom row of tiles and remove grout / sealant where the tiles abut the tray.
Thanks, do you think many plumbers would do the whole job, or would want us to retile etc, if so we can sort this? Any ideas of what a plumber would charge? I am based in Coventry West Midlands.
Sarah,
ATB
Apologies Jim but what you have not mentioned is the potential damage to the substrate (plasterboard or whatever). If the shower has not been watertight for a while then the bond between the tiles above and the substrate will be compromised. In my experience this can be up to 1.2m above the tray. If that is the case, and the only way to know that is to take a few off, then they all need redoing as will the substrate. Anything else will be a form of temp fix so it WILL start again.
BEFORE doing anything else Sarah, might I suggest you take a good read through your insurance documents. However, DO NOT, talk to your insurers UNDER ANY CIRCUMSTANCES.
What you are looking to see, is if you have a claim for 'consequential damage' i.e. damage as a consequence of a slow leak. Many insurers now actively exclude these from their policies which is why you must check first before contacting them.
IF you decide you can, and wish to, go down that route then get a pro in to write you a report on the whole thing and detail what needs to be done to put you back to the position you were in prior to the event.
Have fun.
Have seen cases where the last row of tiles are angled out towards the shower tray. Never thought much of it until now, maybe they had the same problem?
Only said I'd seen it a few times, struck me as odd, now there might be a reason why it was done, so the tiles reach the tray rather than move the tray.
Thanks for the patronising reply when I was just trying to be helpful. Maybe I should have called myself something else rather than Vicdiy to avoid such an unfair comment. I may not be a professional but I have done loads of jobs at my own house and relatives ( for no charge) and they have all been done to a high standard. Tell me what is wrong with checking and replacing sealant every six months when it can leak and cause all sorts of damage. One of my daughter's recently moved into a new house and had a wet patch in the hallway, although the sealant around the shower looked fine this turned out to be the problem,it took me about an hour to rake it out and reseal what is unreal about that!
Please read my comment Vic.
We do this as a profession. We take full responsibility. We can be taken to court if it is not correct. How many more reasons do you need? They, among others, are some of the reasons we do it correctly and to formal standards where they exist and industry best practice where they don't. Please don't go there.
We are talking about sealing a shower tray aren't we ? I wouldn't dream of commenting on anything requiring professional knowledge.
Hi vic, I was going to say post #23 puts it better but Dave has replied whilst I was away.
Hi again vic, do it right once and it will not require checking every 6 months bud. That was the main stand out point and hence my post.
I really enjoy reading the posts and comments on this forum as I like to pick up knowledge from those that know better. I think in future I will just read and not bother commenting. I was a senior project manager involved in multi million pound projects but I do realise that there is no substitute for hands on practical experience.
Reply to Shower Leaking into the kitchen in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
I have a leak from my shower, it's coming down into my kitchen. I've had the sealant, waste pipe and tray all checked. I've also had the shower...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Do you recognise this shower drain rubber seal? I have searched the web and common plumbing spares suppliers but I cannot find which it is. It...
