Discuss Shower mixer valve inlet centres (what does +-5mm mean) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've come across a few thermostatic shower mixer valves where the technical spec states the inlet centres are 150mm (+- 5mm). What does the +-5mm mean, if on the valve body the distance of the inlet holes are fixed at 150mm.
Does it mean that the inlet centres on the wall can be between 145-155mm and for example if the inlet centres on the wall were spaced at 145mm the valve body will still fit?
The + or - 5mm is the manufacturer's tolerance, they can supply between 145 - 155 c/c and you have to fit to what you get.
Have a look at this one - Bristan Zing. It states dimensions for Fitting: 135-165mm adjustable inlet centres.
If the nut on the valve body is fixed at a certain distance, how would it fit to an inlet centre within the above 135-165mm range. I'm i missing something? Surley the nut and inlet need to have the same distance between their centres for a snug fit?
Your usually safe with 150mm centres unless it's a small Mira etc @ 120mm centres
That would be adjustable centres, this side of a tile.
Reply to Shower mixer valve inlet centres (what does +-5mm mean) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm in the process of refurbishing my bathroom. I'll be replacing the existing bath with a walk in shower. Will be installing a thermostatic...
Hi, in order to replace the solenoid on my shower I need to take it off the wall (bad shower design). I've got all the electrics disconnected...
Old shower (20-30 years) had a Mira Excel installed that split in the inlet - not repairable from what I can see as the inlet pipe is now...
Does anyone know of a concentric mixer shower valve that will fit 3/4" threaded connectors coming out of the wall @ 150mm centres? I would like to...
Any plumbers can advise the best way to convert the current mixer valve tap to cold water supply inlet for electric shower. I have mixer valve...
2K
