Discuss Shower pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hello all ,
I had had an issue today I came across a shower pump I haven't seen before.
The Stuart turner 1.5 bar single hot water ,
located 1st floor next to the cylinder / feeds only 1 wash basin upstairs 2nd floor
customer said pump is not working anymore it used to work great then it started intermittent now it completely stopped
the Stuart turner single pump has also a Stuart turner control module installed therefore I have never seen it before and didn't really know what's the issue.
Before re I give a price to replace the pump I would like to try to find out what's the issue.
this module helps the pump from running dry and any sort of restriction it would shut the pump down straight away so the pump wouldn't get damaged.
now is your turn does anybody know what it could be ?
The module didn't show any light on those 3 lamps I assume I could do a restart but what caused the module to lock out ?
Atched you will find the module
[video]http://www.pumpserviceltd.com/stuart-turner-commercial-pumps/control-module/control-module-41011/prod_424.html[/video]
Sorry cant help , but stuart turner tek lads are always happy to help
Thank you dude , I will give it a go. I just thought someone knows the fault as well as the old pump
Reply to Shower pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
