Discuss shower tray outlet position choice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stokegolding
Does anyone know of a shower tray where you can ask for the outlet in a certain position. We were hoping to set first floor shower tray as low as possible and have the trap between the joists but the outlet of the tray we were thinking of buying would come out directly on to a joist. Plumber says you can buy trays where you can specify the outlet position but does not know which manufacturers. Any ideas/tips?
Look online at various models, they all have the dimensions on them, and do the prep work to suit whatever one you pick, or choose one from a merchants display and write down the sizes, wouldn't go bespoke, too expensive and not needed if you research properly
Reply to shower tray outlet position choice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Is this new shower tray defective and would you install it in this condition? The void where the wax deposits were (last photo) is between 4m-6mm...
J
Hi, I've installed a macerator a while ago to manufactures specs, toilet, sink and shower. One problem I've always had is the shower tray is slow...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This...
Hi Just moved into a house and in process of renewing sealant around the shower cubicle. Feel free to skip to the bottom to get the question...
