Discuss Shower waste cap end leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Ordered a Mira flight level shower tray and it has come with a shower waste with markings "Pivotal Kohler".
It has two compression outlets, one on the side, one on the bottom - for different uses.
The side that connects to a pipe seems to be fine but the capped end just has a rubber ring to press against the face and this leaks.
What is my best option here?
Is it possible to buy a sealed end piece of 40mm pipe that I could compression fit?
Could I just fill the threads with some goop?
Any help appreciated, thanks :)
Reply to Shower waste cap end leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
