- Messages
- 2,718
How do you guys measure up your side exit flues if it's a long run?
I did a 3m straight run, used a laser level where I wanted the flue hole and then dropped the template about an inch from the side exit flue guide line but the fall wasn't as much as I'd hoped for. I might have to knock a bit more wall out so I can put abut more height on the terminal end of the run.
