Discuss Sirrus TS1600 Alternative Dial in the Canada area at PlumbersForums.net
Plastic Thermostatic Dial has broken. Need alternative option as Sirrus Ts1600 is discontinued. any suggestions? TIA
Reply to Sirrus TS1600 Alternative Dial in the Canada area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
