Discuss Size of shower proformer in Wetroom - does size matter. in the Canada area at PlumbersForums.net
Hi, I'm looking to change my downstairs bathroom to a Wetroom. It's currently an enclosed shower with a wooden floor on joists. I'm going to have the wooden floor remove and a Wetroom installed with a tiled floor. Please see picture of upstairs bathroom showing large tiles on the floor and mosaic tiles in the shower area, upstairs refit used a 1500 x 800 pro former.
My question is regarding the shower tray proforma.
I would like the linear drain to be along the wall (1500 x 800cm) so prefer that one, or the other option would be a smaller square pro former with a drain under the shower head (900x900) . Please see rough drawing. The length of the bathroom is 190cm.
My question is, is it better to have a large pro former 1500 x 800 to ensure no leaks when showering as it covers a wide area or can I consider the smaller 900 x 900 with the linear drain under the shower. I know the floor will be sealed but just wondered if having a larger pro former would be the wiser choice ?
Would appreciate any help, Thank you.
It really doesn't matter what you use.
It comes down to the look you want.
It will be easier to screed the shower base with a grate that covers the width of the shower.
It will also be more comfortable to stand in the shower.
With the grate at one end, you have the option of not using mosaics on the floor and have larger tiles fall into the grate.
Far better look if you ask me.
Hi Many thanks for the reply, yes I think I will go for the larger version, thanks again.
Reply to Size of shower proformer in Wetroom - does size matter. in the Canada area at PlumbersForums.net
Void under shower former My recently installed solid resin shower tray / wet room former has around 4mm flex across a dinner plate sized area in...
Hi Folks, I am building a wetroom from scratch, i am a very experienced plumber and bathroom fitter but amazingly have never been asked to do a...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This...
I have bought a replacement 1200 shower door & 1200 x 900 tray, ready for a refurb starting soon. The current door & tray is in a recess, which...
Hi there, I'll soon be installing a SONAS 1500 X 800 resin shower tray in a bathroom that I am renovating. It does not come with any sealant or...
2K
