Discuss small chrome waste pipe size?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
anyone come across that small chrome waste thats less than 1.25'? need a fitting for it but dont know the size.
Mc alpine do this or it might have to be an 1"1/4 comp
I've always used an 1 1/4 comp str or 90, may need a bit of ptfe
I get them at Plumbs but if you ask Ray Nicely I'm sure he stocks them.
It comes with 2 different sized rubber washers, are you sure the chrome pipe is less then 28mm?
Might be 28mm.But at the moment they've got the chrome pipe going into an 1.25' compression bend and its just flopping about in there all loosey goosey! So its defo smaller than 32mm
Reply to small chrome waste pipe size?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Everyone, Can anyone help? I have been searching but with no luck. I am trying to fit a Duravit shower trap which has a 50mm outside...
1K
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at...
It's not every day I deal with 110mm soil pipes, therefore I do not have a selection of different fittings at hand to try what combination fits my...
Hi all, I'm in the process of fitting my freestanding bath. The supplied waste chrome pipe that runs into the floor is an unusual diameter -...
1K
Hiya - posting in this forum as I'm guessing this relates to my neighbour above's boiler, but I may be wrong so please say if so. Basically the...
