Discuss Solder fittings advice pls in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
When using solder ring fittings is it important to have one end of the pipe open to allow pressure and fumes to escape?
I had a terrible job trying to solder a short section of pipe with an isolation valve closed on each end. It wasn't till I redid the work and opened one end that I could get it to solder successfully.
Was there water in the pipe ?
100% yes as water would of gone to steam and pressurised the pipe need to keep an open end where there’s any water to steam / boil off
Reply to Solder fittings advice pls in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
