Discuss Soldered pipe advise!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Samantha1
Hi I wonder if someone could please advise me if a soldered join on a radiator pipe is possible to leak after 2 weeks? Thanks :001_icon16:
Yes if installer didn't do it properly and it's a gravity system. Un likely on a pressurised.
How would I know if it's pressurised, sorry my plumbing knowledge is not great! X
It flooded out floor x we have a video of water damage but not the leak... X
I would expect any soldered joints to be water tight for a long while. 2 weeks indicates an incorrectly soldered fitting, unless there has been some sort of mechanical damage.
A properly soldered joint onto a copper pipe will not leak ever - unless it has been very abused - like hit with a hammer. One of the few times I have ever seen properly soldered joints broken was severe freezing in the winter 2010.
What sort of pipe is the soldered joint onto? Is it copper or chromed pipe?
It's a copper one x
Reply to Soldered pipe advise!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
PSxxxxxx
