Discuss Solved: how to open very very old water tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Solved by snowhead: "Just pull on the chrome head I believe, you may not need to remove the centre".
Hi guys,
Would you please share your knowledge on how to open the following water tap. It is an very old tap, one I never saw in my life. Most of the internet DIY are for newer versions which I know how to handle, but this one is out the timeline:
Imgur: The magic of the Internet
The problem is the dripping tap and I have no idea how to open it.
Very very old?
Are those the right pictures? Looks reasonably modern to me. I'm going to guess at mid 90's. Are those chrome-plated plastic tapheads that just pull off?
those are metal chrome-plated tap heads and there is a blue plastic one that fits right into that hole.
i tried opening it with big screw, with tweezers maybe to grab the screw head, but no results.
Observations.
That's not old, I doubt it's even half my age.
The wall tiles look British, 150mm x 150mm (6"x6" old money), but the tap looks continental.
Maybe an early import or brought over by the Continental householder.
Or this is not in the U.K, maybe Colonies?
Looking down the top with the centre cap missing there are 4 nylon claws that appear to hold the top on.
I'd say a sharp pull on the top and it'll release.
The claws may have been locked in by the centre cap.
snowhead, it is in Germany and from the looks of the apartment is no sooner than 90's as Ric2013 puts it. I still think it is a very old installation as I never saw one with no regular screw in those tap heads.
so I have to pull those nylon claws in order to release the tap head?
images
That's a slightly more modern version but similar.
Reply to Solved: how to open very very old water tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Gas combi Boiler Mains fed in all taps and shower How do I balance the water pressure in all faucets in my flat. Every tap/water...
Hi All, I replaced my existing washbasin bowl set with new Shaw and Mason forward bowl set spindles and chrome handles. The water pressure has...
Hi All, I have replaced my existing Shaw and Mason chrome set with the Shaw and Mason forward bowl spindles/ Handles. I have kept the same tap or...
PRJSyd
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
