Discuss Sound of running water but nothing is turned on? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Water is constantly running through the cold pipe that leads directly from my stop tap through a few meters of pipe along and then upstairs. I can clearly hear it (and so can the rest of the family)and feel the vibration caused by the flow of water through the pipe. When I turn the stop-cock off it stops. Nothing is turned on. Toilets are full and not leaking. No problems with anything water-using fixture save a slight drop in pressure you'd expect when more than one appliance is being used at the same time. After hours of searching no signs of a leak anywhere. And this has been going on all weekend so if there was a leak I'd presume water'd be everywhere given the sound is noticeable. No wet ceilings, no sound of spraying water under floorboards etc. Very confused as I think I've eliminated everything. Can anyone help please?
How old is the property, could easily be a leak under the floor, any signs of damp around the outside of the property.
It's a mid 50's council property. Concrete floors. No signs of a leak from upstairs. The bathroom is directly above a part of the kitchen where I know water would come through (previous with son!). Celing plasterboard is dry and solid - sounds hollow when I tap it. Pressure in shower is lower than normal but still working fine. No sound of a leak from bathroom but it's the only water up there (upside down glass on shower tray etc). Could it be an external leak simply transmitting sound along the pipe? Thanks
50s council house. No signs of an internal leak and the sound has been there all weekend. Bathroom is directly above kitchen and from previous with son (!) I know where water would leak through. Ceilings are solid and hollow sounding when I tap them. No signs of an external leak, but could the sound from an external leak transmit along the pipe? (when I turn the stop tap off the same vibration is still on the external side). Thanks
Yes it could be an underground burst, but I remember correctly it usually goes louder if you turn it off at your internal stopcock.
Thanks Pete - but nothing in the loft. No overflows, no water running away externally, just the sound and vibration of water going through the internal pipe when nothing water-related is being used. I can't fathom it....
Reply to Sound of running water but nothing is turned on? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
