Discuss ST699 contoroller replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Colin68
Hi All,
I tried to replace an old ST699 controller for a CT9400C but there's about 8 terminal connectors on the ST699 and 5 on the CT9400C, any advice for an alternative controller? .. current system is 'conventional and Y plan
Yeah I want to use a CT9400C but unsure about the fitting (wiring) .. I have turned this sort of work down before as unsure but now need to bite the bullet and get the first success under my belt .. not sure how 8 wires go into 5 teminals ( on the CT9400C)
i think i have a app for it on my ipad but her in doors has it at min with all there diagrams on
thnaks Bod ... newly fitted ST9400C for the customer and he's happy .. even managed to discover the pump was wired incorrectly and running all the time even when there was no demand for hot water or heating .. don't suppose you know anything about SMC controllers do you?
Reply to ST699 contoroller replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the...
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar...
2K
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
I have an issue with a Worcester Greenstar 29CDi Classic boiler. I replaced the old thermostat controller with a smart dual-channel HIVE one. I...
Home owner looking for some advice pls. We have a megaflow system which we are considering removing as the tank takes up a lot of space and we...
