Discuss Stop frost stat kicking in? in the Central Heating Forum area at PlumbersForums.net
We have a 15 year old boiler situated in a poorly insulated garage (fixed to the same wall as our bedroom).
When it’s 5c outside (16c in house) it’s about the same in the garage and the frost stat kicks in. Twice a night we get the woken by the boiler coming on, the pump working and the pipes creaking.
Which of the following do you think would stop it coming on? I have £3k to solve the problem.
  1. Tube heater and insulation in garage
  2. Build insulated cabinet around boiler, frost stat and pipes
  3. Fit new boiler that is designed to be used in garages and has insulation built in (is that a thing?). New pump.
  4. Something else / combination of above
Put a new standard frost stat in with a pipe stat as well on the return pipe.
At the end of the day the frost stat is doing it's job. I'd insulate your garage more and maybe add a radiator.
Thanks @EvilDrPorkChop . Do you mean a regular radiator linked up to the central heating? Presumably this would heat up the room while the CH is on and then the residual heat would hopefully see us through the night? Is a tube heater a bad idea?
I would say answer depends on how you use your garage.
If it’s a workshop and you spend time there eg wood turning then I would insulate the garage and if that doesn’t do it , add a simple oil heater with a timer and thermostat. You could adjust this such that it kept the garage temperature above the point where your boiler kicked in on its frost stat.
My theory is that you may as well use the heat off the central heating to put a little into the garage, along with the fact that when the frost stat does kick in then it'll put some heat into the garage also to knock it off quicker, and help keep the boiler and pipes warm.
I think your best thing first would be to insulate though.
Reply to Stop frost stat kicking in? in the Central Heating Forum area at PlumbersForums.net
New built home. Has a combi on a 2 heating zones. The issue boiler located inside garage has a frost stat and a status ct100 pipe stat. The boiler...
My boiler suddenly seems to come on at random times for a few minutes throughout the day and night. It is a Potterton Suprima in garage. I...
Hi. I have an issue with my Ideal Logic+ System S24 boiler which I hope someone can help with. Below is as much detail as I can think of. The...
Just checking my understanding of frost stats.. My customer has a boiler in a garage (12year old Vaillant/British Gas boiler on an unvented...
4K
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented...
