Discuss Stop Valves for LDC 50mm Connection in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello,
I received an offer from the Water Board for a LDC MDPE 50mm connection.
We are currently laying the works required in our boundary.
A stop valve is required for the external meter chamber but we are unsure which type to buy?
There are many available online with substantially different price points.
The water board have also been no help on this.
The water board will supply the stop tap and meter as it’s there responsibility to maintain all you will need is a connection out
Also don’t forget it will need to be flushed and chlorinated as it’s 50mm specialist job
Hello Shaun,
Please see the attached screenshot of the instructions given to us by the Water Board, I have indicated what I mean.
Thanks for this Shaun.
The price is quite a lot for this.
I notice the price of these vary. Is there any logic as to why we require the one that you suggest?
The pipe is MDPE, I don't know if this changes anything?
You will need a drz underground rated it will be expensive as it’s solid brass
Reply to Stop Valves for LDC 50mm Connection in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, I am converting a house into 11 flats run by electric only. Each flat will have a kitchen and a mini electric boiler to power the sink...
1K
We just had a waterhole bored and were lucky enough to find a flowing artesian, which delivers just over 500 gallons an hour without needing a...
G
Hi, I have recently had a water board inspection This is what the report said about the filling loop on our press unit for a biomass boiler…...
1K
Hi all. I am in desperate need of a second opinion. I have two pipes (hot and cold water) that once ran down from the bathroom above and round...
1K
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
