Discuss Strange problem - mains water running for 10 secs every few mins in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got a strange issue and hoping someone has some ideas please.
The other day I needed to switch off the stopcock to work on my toilet. Water was off for an hour or so and since then there is a strange noise every few minutes. It sounds like water running in a pipe and is coming from the same area under the sink as the stopcock. Also in the upstairs airing cupboard I can feel the water pumping through one of the pipes (think it's a cold water mains pipe but not sure).
I have a combi boiler so nothing going on with a loft tank. Tried turing the boiler off just in case it was related (it's not) and have also bled radiators (there was a fair bit of air in the system).
The only thing that stops this intermittent issue is turning the stopcock off again.
Any ideas? thanks in advance!
Hi - thanks but it's not any of the toilets, I checked them. As I say the sound is coming from near the stopcock - the toilets are silent and are not running (well one of them does run a bit sometimes but that's just the inner plug not always sealing properly after a flush - just flushing again solves it) and they are not overfilling...
Found the problem and it WAS one of the toilets running that was to blame (sorry Scott_d)!!
The plug is leaking just a little bit and the water level is only dropping a tiny amount which is why I didn't notice it.
Thanks a lot for the advice!
Reply to Strange problem - mains water running for 10 secs every few mins in the Plumbing Jobs | The Job-board area at PlumbersForums.net
