Discuss Strap on boss for 80mm downpipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sheff paul
Don't do a great deal of plastics but struggling to find a strap on boss for a 80mm down pipe do they do em?
Is this the same thing in thinking of? Ribbed shank and all? Thought Williams did plumbing parts?
a downpipe is a rwp in my plumbing speak be it 68,82 or 110. I need a new dictionary :)
pointless tho as you need an air break between the two so its best to use a branch and bend.
Seen plenty go straight into downpipe with a blob of silicon.
Whats the air break for, incase the downpipe gets blocked? Most boilers have a condense trap so no smells.
yeah, if drain/rwp blocks with leaves like most have today with this wind. sometimes a hopper is best if room.
So if you were to use a downpipe for a condense you'd use downpipe branch and?
A bend then drop your 1/14" or 1 1/2" into it to create an air break.
If you don't have a break and the conductor chokes the boiler will fill with rainwater.
Like this
Reply to Strap on boss for 80mm downpipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
