Discuss strap on boss in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mfgs
Are there any strap on boss' on the market that don't wrap around the pipe? I have to tap an 1 1/4 waste into a 4 inch plastic stack, but the stack is wedged into a corner so impossible to get anything around the back of it. So the only ones I have ever used wont be possible.
Not used the 2 piece glue on type for years, still got the clamps in the garage
Get a normal strap on one, cut the strap off in the way leaving as much as possible. Fit as usual making sure the surfaces are clean dry and roughed a bit. use lots of solvent, lean something against it till it sets and dont let water go down the pipe foe a few hours. if you are unsure and it wont be seen you could put a couple of short self tapping screws in or fish a cable tie round the back?
We used to use gap filling cement rather than glue, it was grey in colour and melted the pipe and boss together never had a problem with them (apart from trying to take them off haha)
That's what solvent weld does?
just did a search on strap ons and got some interesting results, especially off net mums!!!!!!! I must have been through a sheltered life :) Only wanted a glued boss as discussed !!
Lol lame just did the search with netmums !wtf man !? The next time I hear a woman going on about netmums I'll be thinking you dirty gertie I know what you're going on there for!
The main issues with strap on bosses comes from not cleaning the areas before gluing. Use a cleaner and if there anything other than a good contact use gap filling cement as Kirk suggested.
Gap filler is handy when you loose your holesaw and have to cut a hole in the pipe with a hammer and screwdriver :wink:
and I'll bet , especially if you here a tube squirting sort of noise, youll never bend over in front of the missus again in the dark :)
Reply to strap on boss in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
I've recently replaced an immersion heater for a direct cylinder, for 2.75-3kW. The new one seemed to be working a week before I got a callback. I...
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
Hello. This is my first ever post asking for help. I had a bathroom renovation done early this year which I did myself. I wanted to have a low...
I have an underground stopcock that is leaking a lot through the gland. I have dug down three foot to access the stopcock as I also want to move...
