Discuss Stuart Turner pump is slow? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there,
recently changed the pump for my shower from a cheap and noisy 2 bar pump as the pressure it was suppling was rubbish.
We had recently changed the shower to a tower shower with body jets and stuff.
Heard that stuart turner was the mutts so got a 3 bar pump.
Changed the feed pipes to 22mm (from 15mm) by running a new 22mm pipe from the cold water storage tank in the loft, and re-running the pipe that comes out horizontally of the surrey flange in 22mm from the hot water cylinder in airing cupboard to the pump that sits beside the cylinder.
The outlet goes through about 2.5m of 15mm barrier pip to the shower and only has one elbow where it conntects to s shower plate adaptor thing.
Thing is it doesnt seem like a huge difference. Is there a better way to feed the shower so help it supply more water? is a small increase in pressure all to be expected. it has a total of 4 outlets but with only 2 on it is so weak.
pump is really quiet though thats good.
Could you test the flow straight out if the pump ?
And are any valves full bore ?
how could i test it directly?
I would need to add a small pipe or something to direct the water? would it fill up a bucket too fast and how would I turn it off?
there is a gate valve on both hot and cold feed pipes. the pump flexi hoses have isolating valves on them if that helps
Into a bucket yes and short bit of pipe with a valve on the end
I would say your fine on your inlets think it's your pipework out that's the problem
I wasnt aware at the time and just changed like for like. so the 15mm pipework got refitted as 15mm from pump to shower.
It is only a short length, but can that be enough to restrict it that much?
So likely the only way to beef up the presure/flow rate is to widen the pipes to the shower. that sucks since the bathroom is finished and tiled!
Sorry to say yes especially if it's been done in plastic
Didn’t realise that being in plastic would make a big difference to copper, if any at all..?
May I ask why it isn’t as good as copper ?
By the time you talk of insets your internal bore is around 10mm
There was a kink in the flexi hose into the shower that was hidden, the connection was only finger tight for some reason. and both mesh/sieve filters of hot and cold inside this flexi hose between fixed pipe and shower outlets seemed to be gunged up with like plumbers mate or something gooey and sticky.... well suffice to say, removed those issues and all is good. I can almost feel my skin shredding from the pressure!
Reply to Stuart Turner pump is slow? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
