Discuss Sunvic 3 port valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
homewizard
Hi ... I'm changing a 3 port Sunvic valve (MK1453). I've read that instead of replacing the body you can replace just the inners as this is held by 4 screws. If this is possible, will the system need to be drained first or is there a 'shortcut' ? Thanks in advance for any replies.
You defo can with the two ports so i would think you could, yes you would have to drain the system , or at least to the point where the valve is.
Personally if I'm going to the trouble of draining it down, I would change it for a honeywell. But depends on your level of competence.
Yes the guts will change on the three port, do it on the camray 5 combi's, which are the danfoss ones. If its a stand alone three port then Pheonix Services has the right idea. Bin it for a Honeywell.
Thanks for the reply. I know that everyone harps on about changing it for a Honywell but it has lasted 25 years so that can't be all bad can it?
unless you have a very good reason,change the complete valve,if not you will probably regret not doing so....
To coin a phrase......
They don't build stuff like they used to :)
Reply to Sunvic 3 port valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I'm going to replace the 3 way vale on my open heating system. Hoping someone can advise. In the picture, to isolate the valve I am going to...
Hello. My home's Rheem water heater is dripping from the drain valve. It is strange as it seems to sometimes spit out some water and then stop...
My 3 way actuator valve has gone on my central heating. I think it's a combination of the valve motor burning out due to a stiff valve on the...
1K
I am a DIY'er and I need to replace the 3-port valve of my bungalow. I am aware I could bung the F&E but I don't really want to chance this...
2K
Hi, I have I blend valve from Nu-Heat ( they bought it from Reliance, as per attached spec). I have dismantled the valve now 3 times and...
