Discuss Super quick question re Flexi & push in the USA area at PlumbersForums.net
Hi
Swapping over my kitchen tap, thought would be straight swap but not the case.
Old tap = 15mm copper into pvc/push fitting
New tap = European size Flexi hose into pvc/push fitting.
Now I have the European to 15mm adapter but there is no threaded insert in the pvc for it to grip into.
Am I right in thinking tap tail adapters are what I need here?
Piece of 15mm tube tighten onto the compression fitting then insert into pushfit
You could either:
1. Get two short lengths of 15 mm copper pipe. One end into the compression end of your adapter, the other into the push fit connectors. No insert needed if using copper.
2. Swap the adapters for Screwfix 6089R. Threaded end screwed onto your flexis, plain end into the push fit connectors.
I don’t think the plain shank is long enough to go into the speedfit fitting? Better off using a short length of pipe and the Male Iron fittings you have already bought.
Well done.
Yes it’s surprising how much goes into push fit fittings; 28-32mm depending on make.
You're spot on, the tail didn't get anywhere near close enough. Now the wife insists I do something to cover up the big hole but have convinced her for now it makes sense to leave open for a while until we are wholly comfortable it's a good/watertight connection.
Reply to Super quick question re Flexi & push in the USA area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
