Discuss System boiler issue : rads very Hot middle of night . in the Central Heating Forum area at PlumbersForums.net
Boiler was serviced 2 months ago by Vaillant . Timer /control seems fine. Thermostat looks less than 3 years old .Timer turns off heating /water at 10pm due back on at 5 am . Friend woken up by warmth from rads .All rads too hot to touch almost .
where could the issue be ? cheers
Do you have a hot water cylinder?
Is the programmer set to reheat the hot water cylinder during the night?
Do you have a single '3-port / Y-plan' valve that controls where the flow from the boiler goes or two (or more) '2-port / S-plan' valves?
Which model boiler do you have?
The control could be faulty .org the microswitch inside the motorised valve can get stuck. The microswitch is what brings the boiler on when motorised valves are installed, as they have a permanent live and switch live (switched via the microswitch).
Top one was changed 3 months ago.
Reply to System boiler issue : rads very Hot middle of night . in the Central Heating Forum area at PlumbersForums.net
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
Hi I am somewhat confused. My daughter has a combi boiler bought 2-3 years ago and has it timed to come on in morning for an hour and at night...
Hi all. I noticed this winter my living room rad only get hot in the top half. Radiator is 1600mm(DP SC) double panel single convector. System...
B
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
