Discuss Tap connector - 1/2 inch to compression? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I was wondering if someone could advise me how to connect the flexi hose from a new tap that I've purchased to the existing pipework.
The photo below is of the existing pipework and existing flexi hose. The flexi needs to be removed because the new tap requires an M10 connector rather than half inch nut. The new hose is M10 to half inch nut. I don't understand the threads marked in the photo - are they part of the flexi hose? Is the new hose inappropriate for the existing pipework and I need to get a hose from compression to M10?
Thanks in advance.
1. M10 refers to the threaded end which goes into the tap.
2. Assuming the 1/2" nut is a 1/2" female connector, you need two off 15mm compression to 1/2" male "irons" (which are actually made of brass). For example, Screwfix Male Coupler 15mm x Ā½
3. Undo and remove compression fitting 3 in your picture. You can probably re-use the nut on the pipe and its olive, discarding the equivalent parts from the new "irons".
Great, thanks very much for your help.
I just watched a video on youtube where they recommend using ptfe on the olive, would you say this is advisable?
Post a picture of the new flexi and tap it maybe a 3/8th loose nut the 10mm to 15mm flexis are readily available from the main plumbers merchants cheers kop
You are quite right how often I see that on 3/8. Especially when buying grohe taps they come always with 3/8" flexi hoses
Reply to Tap connector - 1/2 inch to compression? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
