Discuss Thermal store - very low hot water pressure. Help/ideas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Very low (trickle) hot water pressure at outlets. Albion mainsflow indirect cylinder. Help and ideas please!
I have had one similar issue. Had been heated by solar, coil scaled up inside. I disconnected mixing valve, added an elbow and a length of copper to the top section of the coil and kept pouring in a strong lime scale remover. It was so bad it took me several hours. I did plug the bottom for a while to give it chance to eat away the scale. The only other option new cylinder.
One question though did you try just adjusting the valve to only have cold through? if you have full flow cold through, there is your answer.
good luck.
good luck.
Get someone who is g3 qualified out eg unvented they should know what there doing
Reply to Thermal store - very low hot water pressure. Help/ideas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How a thermal store boiler works! I’ve got an old thermal store boiler and I’m trying to work out how it works. From what I understand the boiler...
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
