- Messages
- 5,172
Ok a client of mine had a problem with an wireless drayton room stat. As said before on here, always easy to just replace first and see if it works. I changed the receiver and stat for the new drayton and it worked ok. And has for a couple of weeks. Then he said it would not come on if he pressed the advanced button. Only if he reset it on the receiver. So i went there and it was working fine, no fault. Then I get this message below
Ok got home at 6- heating came on (from 4,30) Temp set at 22 and currently 20.5...thought hour and half should be long enough to get to 22.....Boiler not burning but why? No green light. Constant red which suggest a problem and batteries should be removed and reset. So something not right. Pressed override and boiler fired up straight away but had to advance the setting as well. Conservatory rad only mildly warm while kitchen rad v hot....any advice ? Phil
Any ideas guys
Any ideas guys
