Discuss Thermostat wiring questions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Hello,
If a previous thermostat has been removed from a wall fixing and been made safe and plastered over, can it be dug out and reconnected?
Thanks,
Tom
it can if the wirings still there, would need to be tested and make sure the wires ok first but yes
Ok, thanks. My next question is regarding buying a new thermostat. Are the connections used to wire it to a boiler universal? I.e. the wires will connect to any thermostat purchased?
no tbh best to either get a spark/heating eng out to check wires are ok/ check which stat you could have
Hi & welcome.
check what supply your old stat had from the wiring box/boiler is first. might be volts free or have 3 wires,1 for a neutral.
The old thermostat has been plastered over. Will a plumber be willing to dig that out, or will I have to do it in preparation? I need to have a new thermostat ready for him to install.
How deep is the plaster? or do you mean the 1g back-box where the wires are located. If your unsure I would leave it up to your plumber
Fear you will get hit with a 38.11 closure shortly unless you register dear guest.
And you 2 could help croppie out here.
Please register with us and start a new thread to receive additional answers to your question.
Reply to Thermostat wiring questions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I live in a really remote part of the Highlands, so paying for a plumber (or electrician?) to do this will be brutally expensive, so I need to...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
Hello, my Vaillant VRT 392 Thermostat just stopped working, it's completely dead, I read another thread suggesting changing batteries, but this...
Hello. My mixer shower (non-electric) recently started running luke warm. I know this can happen at this time of year over winter but I've been in...
We have recently moved into a property which has a Worcester Greenstar Highflow 440 Standalone Combi gas boiler. This appears to be a relatively...
