Discuss Toilet seat hinge HELP- am i a morron?!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jaronious
I am having the most painful experience trying to put my toilet seat back on.
It has been loose for a long time, so i managed to get it off to have a look...but can't get it back on!
its a top fixing toilet seat, with no access to the underside.
it has plastic hinges, where the seat slides on and latches into place.
i can tighten the screws back up
but i can't actually figure out how to get the seat back onto the bolts.
the seat is all one piece of plastic, it doesn't come apart so that i can fit the bolts from above
there has to be an easy way??
here are some pics, if anyone has had any experience with this type of seat!
i haven't been able to find it anywhere!
thanks!
jalbe
think the make might be roca.
Take seat fixings out of the toilet and these slide into the back of the toilet seat with the bolts still attached then feed the bolts back into the 2 toilet holes still attached to the seat then screw back down
Depends how the screws are fixed from underneath, possibly self tightening bolts, in that case be careful how far you unscrew them.
Sorry misread your original post i have looked at the pics and it looks like you will have to take out fixing bolts and move it forward slightly to get at seat fixings
It just slides back onto the baseplate. There are two ridged sliding buttons on the bit connected to the seat to secure it when installed. Make sure these are In the open position or it won't go back on
Sent from my GT-I9100 using Tapatalk
thanks everyone.
Kay-jay this makes the most sense.
however there are no buttons that i can switch to open.
the baseplate is solid.
It would make sense just to slide the fixings onto the baseplate and then screw the bolts back down, but there is no access to the bolts from the top of the seat.
all very frustrating.
Use a couple of toggle bolts into the holes for the seat. Works a treat.
i feel terrible cos i just have no answer to the op's problem with this seat....sorry
thanks!
jalbe
View attachment 6368View attachment 6369View attachment 6370View attachment 6371View attachment 6372
You need to go into any of the plumbers merchants and ask for an ASTRA wc seat
the original fixings are pushed into the holes from above. then you screw them in and it expands in the hole until tight. there is no wingnut underneath. when the baseplate is fixed in this way then the seat just slides back onto it.
in picture one you have the baseplate attached to the seat, and in picture 2 you show the fixings connected to the pan. this is wrong. correct way is to fit fixings through the baseplate and secure, then rest of seat slides on.
Reply to Toilet seat hinge HELP- am i a morron?!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi, as the title suggests i need help finding this type of toilet seat, i ordered one but completely forgot to check distance between fittings and...
Hi Everyone Doers anyone know how to remove this toilet seat? It has no push buttons or caps that I can see and I am trying to fathom out how to...
Just moved into a new place and the toilet seat is super loose. Spent about 2 hours trying to figure out how to tighten this toilet seat. I did...
Hi folks, sorry to have to post this but we got a new bathroom a few months ago and the toilet seat was loose at one side. The cistern is...
There has been some useful info in other threads on how to start removing an Ideal Standard toilet set. There's no push release on this model...
3K
