Discuss Toilet siphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bewsh
Alright guys?
i don't really do any plumbing work but a friend has asked me to look at his toilet as you have to pump the handle a few times to get a decent flush. So in guessing the siphon membrane has failed.
my question is though, how do you size the siphon? Just measure the height of the existing one and get one of the same height or do different siphons flush different volumes of water?
cheers guys!
Yeah just make sure u measure it or better still take the old one out and take it with you so the new one isn't taller. You can adjust the water volume to suit on most new ones but ul probably find the standard setting sufficient
turbo 88 adjustable and change the ball valve as the same time if bottom entry and set water level as high as you can (take account of overflow levels etc)
Some you can remove syphon section and replace the membrane without having to remove the whole thing.
Reply to Toilet siphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello! I was checking something in the toilet cistern. I flushed, but holding the float ball, so the cistern wouldn't be filled. With a very low...
T
Hi all, seeking advice on my toilet. (Layman here, please be gentle with me.) When we flush the loo upstairs, it flushes fine (therefore assuming...
Hi all - Our toilet has got very difficult to flush. A couple of very quick goes on the handle will do it sometimes, but not others! So we are...
Hi - I'm not an expert but wondered if anyone might be able to assist. I've replaced an old toilet with a new one. I've used the same water inlet...
2K
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
