Discuss Trouble connecting water inlet connection to plastic pipe in the USA area at PlumbersForums.net
I bought a new sink and it has a 1/2" water inlet pipe but d previous pipework for the kitchen sink is very weird and to be honest I'm not sure exactly what connection I need or what what item I need for to make this work.
please could you help me understand what fitting I would need as I want to connect to my old pipes securely and then use the inlet pipe to connect to my new sink.
Hep2O Plastic Push-Fit Adapting Male Coupler 15mm x ½ - https://www.NoLinkingToThis/p/hep2o-plastic-push-fit-adapting-male-coupler-15mm-x/5970f x2
https://www.NoLinkingToThis/p/hep2o-smartsleeve-plastic-push-fit-pipe-inserts-15mm-10-pack/3158f
Reply to Trouble connecting water inlet connection to plastic pipe in the USA area at PlumbersForums.net
Sonya K
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
