Discuss Twin coil cylinder, upper coil for little wood burning stove in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Evening people,
What’s your opinions on using the above for a 5kw stove. The stove circs will be utilising a heat leak in the bathroom and it’s own f&e tank. The upper coil would be for oil fired heat only boiler and S/Y plan and rads/ underfloor heating. Customer wants simplicity. I’ve not even mentioned to him using a neutraliser or h20 board.
Pro’s and con’s
not rated for gravity circs
Eh! Back in my ‘solar days’ I could have anything custom made from Newark cylinders. I could have a cylinder with a 1.5” coil and 1” oil coil. I wish you’d sometimes look outside the box Shaun lol ;)
true but then that would cost more than a h2 and cylinder with all the other kit :D and i bet the customer would cough
aslong as the cylinders got its own 2 port on the grav side then i dont see why not aslong as its rated for grav circs and the grav side is to regs
It’s only an idea. Like I said, I haven’t mentioned the other options. Have you installed a h20 panel, if so .... what’s your opinion?
I’ve done a few neutralisers and they’re not cheap all in neither, by the time you’ve costed in mats and labour for me and sparks.
H2 is great all wired up and plumbed up just pipe off and go
Reply to Twin coil cylinder, upper coil for little wood burning stove in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Interested on thoughts on this (I've also posted on another forum but thought this might be a better place to ask); Long time lurker, have...
4K
Can someone tell me what size and type of oil fired boiler I need to provide low temperature background underfloor heating in my approx 104...
Hello all, I'm searching for advice on my new system being fitted into a very old stone house in France. We have purchased a thermflow 300L...
7K
Good morning all, I have an interesting one here. I have a customer living in the sticks, off gas in an ancient cottage with no garden. They have...
Hi, I am in the middle of planning a new boiler stove system for my house. As a back story I've no idea when it comes to plumbing, I've done some...
3K
