Discuss U guage or Differential pressure guage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eddiebrown424
Afternoon all happy Sundays to one and all. A quick question. I was thinking of buying a differential pressure guage does anyone use them for TT or are they not a worthwhile investment.
Eddie
i only use a digital gauge one of the anton ones does differential to be honest think i have only used the differential a couple of times. but i dont like the hassle of a water gauge also i do industrial and commercial also lpg so i only need one gauge
Thanks gasmk1 so worth getting one for domestic do you think
Hi Thanks Gasmk1 so worth getting for domestic do you think
i would say so a good tool to add to your tool bag also easier when setting pressures no squinting and add both sides and dividing by 2 to get the actual reading
I have a regin gauge that will measure nat gas and lpg. It uses its own liquid. It's a bit expensive for the liquid. I also have a water gauge both work fine. Dont electronic gauges need to be calibrated? Like any other pieces of our test equipment.
I use mine on the Anton FGA for TT. As it automatically times the 1min let by, 1min stabilize and the 2min TT & then stores the whole result including the timings, pressures reached and passes or fails each part of the test depending on the results. I can then print a paper copy and staple it to the cert or create a PDF to email and / or store digitally. And because it is a feature of my FGA it gets calibrated every year so no need to send off another piece of kit to be calibrated and charged for.
yes I use one all the time didn't pay a fortune for it centre brand make its good to have both I tend to use them for measuring pressure drop across the pipework , and servicing cheers kop
Reply to U guage or Differential pressure guage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
Hi All, does anyone know why the water only fills 1/3 of the way please?
