Discuss Unknown Shower Mixer Valve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
All,
A quick question if any of you can help? I have a shower mixer valve (not thermostatic) that I believe I causing my shower to drip. I’m happy to replace it but I don’t know what it’s called or if I need to replace to whole shower? Previous mixer valves have been easier to replace but not sure where to start with this. Any advice would be appreciated.
Thanks in advance
Pete
It’s a heritage exposed valve , actually made by gummers. It is thermostatic by the way, picture three is a wax filled thermostat.
It has plain 15mm pipe out the wall, then nut/olive attachment so for easy replacement you will need a shower that does the same - not a standard bar valve which connects with 3/4” female threads.
Measure the centres and away you go. I have done a similar replacement using a Mira miniduo with extended elbow kit, as the one I was replacing was not standard 150 centres.
Use an olive puller to remove the old nuts/olives.
Could always replace the guts to this shower instead, depends on the overall condition if it’s worth it.
Thanks BeeGee, appreciate the steer 👍
Reply to Unknown Shower Mixer Valve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
hello all, happy new year! i hope i have posted this in the right section i have a shower bar mixer. the shower runs luke warm. a quick google...
2K
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
Hi All. My Aqualisa Aquavalve enclosed mixer shower valve leaked and gave way and I am looking to replace. I am looking for recommendations what...
hi all i hope you are all well i'm planning to install my shower mixer on Saturday. today i was doing a dry fit and i wanted to show you some...
V
Hi All, Hope all are doing great. I have replaced two separate tap of my bathtub by mixer tap with thermostat. Previous with two separate tabs...
Deleted member 120897
