Discuss Unvented cylinder installed but no G3 qualification in the USA area at PlumbersForums.net
Not hundreds of pounds , last time I used our council it was less than £200 .
That was my thought. Think it's a bit cheaper to notify first than to notify retrospectively but 2-300 sounds about what these things cost last time I looked.
I don't think the OP will need a G3 installer to check if notifying to Building Control as BC would be checking? I think the idea is that a G3 installer might be prepared to pretend he'd done the work and fudge the paperwork accordingly if the OP doesn't want to do it properly through the BC route.
Sorry to hear the OP has been dragged into this situation unwittingly, but good to know there are no dangerous installation defects.
Looks like it's fitted correctly, and overall not a bad job. I've seen qualified G3 engineers do much worse of job, and leave them in dangerous conditions...
I'd leave it, it's fitted now. You'll struggle to get anyone else to sign it off, and the cost of getting it authorised by Building control will just be not worth it.
Thank you for your reply which makes me feel better!
And your suggestion also makes sense!
But if I request the installer to get the certificate for me, he should do that at his cost, right? e.g. he get someone with G3 qualification to sign it off and issue certificate for me
Looks fine only nit pick is combo / inlet valve not above cylinder but that’s only a real issue when servicing cylinder just needs to be drained
Thank you Shaun!
You mean next time when service the cylinder, it has to drain it?
If yes, then I suspect this can be an issue!
As last time when the installer tried to fix a leak in radiator (all radiators were installed by this engineer too), he drained the system but did NOT add inhibitor which should be added once drained the system.
So if next time when do service, I doubt he would bother to service they cylinder i.e. drain it properly and add inhibitor....
Same as this time, he installed the unvented cylinder but did not arrange the certificate to me---he assumed I wouldn't know it;
And last month, he drained the system without adding inhibitor, he assummed I wouldn't know....
Thank you for your point!
If finding a G3 installer first might be pretending he had done the work then certainly I can go for Building Control to do it straight away!
But before that, do you think I should get the installer to certify the unvented cylinder himself? e.g. he finds the G3 qualified engineer to check and issue the certificate?
Or if he cannot, then I get Building Control to check and certify it but at his cost? (Although I know him wouldn't spend £1 for his fault....)
"but good to know there are no dangerous installation defects"====Did you check my photos and concluded this?
If so, I would feel better!
[D]o you think I should get the installer to certify the unvented cylinder himself? e.g. he finds the G3 qualified engineer to check and issue the certificate?
You could always ask, but from your description of him, you'll probably find he'll say BC certification wasn't included (and that somehow you were supposed to know that) and let you get on with it.
I'm not sure what your legal position is, sorry.
I'm not G3 registered myself, nor knowledgable enough to have an opinion on it. However, ShaunCorbs clearly knows what he's talking about and he'd be the first to say if he thought it were dangerous. He's said it looks fine and I'm going by what he's said.
Thank you for replying separately!
The 1st and 2nd regarding legal position is: whether it is his responsibility to certify the unvented cylinder. If yes, then although he might say "wasn't included", but GSR confirmed I do need this certificate! So he cannot let me get on with it?
And If he cannot certify it then I have to get Building Control to do it, but he should cover this cost---although he will try not to as I know him/what he is like.....
Yes, I also got the opinion from ShaunCorbs which makes me feel better! Thought you were another one to give me confidence of the installation :)
You can always have a chat with your local Building Control department ('my father's thinking of having a new cylinder installed by this chap' kind of thing, if you don't want to commit) and you'll get an idea of how helpful they are likely to be. Generally they are interested in keeping buildings safe and compliant and are quite approachable if they see you as someone who is trying to follow the rules.
I suspect what GSR is saying is that the cylinder needs to be certified by someone, which could be Building Control, not that the installer had to do it? I feel it would have been professional for the installer to bring up the matter of Building Control and who was dealing with it before taking on the job, but I really don't know what your rights are. On the other hand, I would certainly expect the work to be carried out to a compliant standard, so he needs to make good anything the BC officer doesn't like, if there is anything.
For what it's worth, the general appearance of the installation does inspire confidence and I think what Shaun is saying about draining will be the cylinder itself, not the primary water of your heating system, so inhibitor is not going to be lost when this is done.
Reply to Unvented cylinder installed but no G3 qualification in the USA area at PlumbersForums.net
  • Article
