Discuss unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mrdog
hi
do you need to inform building control if you are replacing an existing unvented hot water cylinder with a new unvented hot water cylinder . i can fill out the benchmark paperwork , with bpec cert number. do i have to bother letting building control know as its a swap for the same system. my understanding is that you dont need to let them know.
regards mark
Are you G3 qualified? If so, you can self-certify as a member of a Competent Persons Scheme. If not, it needs to be notified even if it's a straight swap.
thanks for the quick reply , ive been on the one day unvented course and had the bpec qualification for that . (g3 twice know) i havent joined a cps as when i have installed unvented cylinders in the past building control have been on the job already . (ive been doing this for 27 years so it grates a bit to have another load of subs to pay to another organisation!!) its just this job has no building control on it , so i thought a swap was ok .
I may be wrong - it's worth checking with local authority / BPEC...
If your Gas Safe then notify through them for a small cost!
Reply to unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form...
