Discuss Unvented Hot water Cylinder query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
JPC
Hoping someone can answer my query - new to this forum.
Currently quoting for an unvented cylinder. No central heating in house at present - to be installed at a future date. Any problems with fitting an indirect cylinder with the central heating to be connected at a later date?
would appreciate your thoughts.
No problem at all. The unused coil or coils can be left open.
Just make sure you get the correct size & type for anything later - solar will need a solar type.
Cheers for that - could not think of a problem if I left it open , but never done it before. Thanks.
I left a cylinder finished but with a unconnected coil on a Friday. The owner & his family didn't use immersion, so no hot water all weekend, because they saw the " open pipes " so thought cylinder was empty! Best to tell customer! :grin:
Fitted mine like this, 2 years later fitted my central heating, no problems 10 years later all still working well.
Thanks MickJ - that's probably the scenario for this job re timescale. Reassuring to know.
I got called out to a immersion change on a direct cylinder , some one had fitted a indirect cylinder instead,, the whole building was electric , no gas . Waste of a coil
Strange as this might seem, but sometimes a direct cylinder was dearer, or similar to price of an identical indirect! Excuse was that indirects are mass produced!
So you got a lot more copper. If any chance of the coil being needed for later, then an indirect might as well be fitted.
Reply to Unvented Hot water Cylinder query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
