Discuss Unvented hot water pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stevern87
Hi guys.
I have just noticed a strange white powdery / rust build up on the pump on my unvented system. Is this normal ?
Please see pics.
Ste
where is the iso valve? directly above the pump?
looks like the valve has been weeping for a while,
if it is landing on the pump, over time could be the problem.
Hey. Thanks for the reply.
Yes that valve is directly above the pump.
Im covered with British Gas so will get them out on Monday.
Should i just keep my eye on it ? What is all the white stuff ?
you need to log in or your reply is listed as above, unregistered!
it will have been a slight leak for ages to slowly build up a crusty mould,
not going to be anything to worry about until it is sorted.
Reply to Unvented hot water pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
