Discuss Unvented hot water tank dripping for 2 hours on overflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
polly_31
Hi all,
Wonder if somebody can provide me with some advice on a CenterStore 120 unvented hot water tank.
The unit has two power inlets - 1 on the ECO7 and 1 for the booster. The main source to heat up the water is via ECO7 which switches on about 2200 and will heat up the water over night.
Approx. 6 month ago I noticed that the hot water tank starts drips via the water overflow valve short after the tank is switched on via ECO7.
The dripping will only last for about 2 hours till (I believe) the set water temperature is reached and will than stop dripping (About 1 drip every second).
At any stage the water pressure is always as expected and I wonder if this is a normal behavior?
The hot water tank is about 4 years old, and didnt not see this at the beginning of the installation. Wondering if the constant on/off switching due ECO7 could have damaged something or if its normal, but than after approx. 2 hours the dripping stops.
Any advise would be appreciated.
regards,
Chris
Time to get a G3 engy in
Reply to Unvented hot water tank dripping for 2 hours on overflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
