Discuss Vaillant Ecotec Pro 28 + WiFi Thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I purchased the following thermostat: BHT-002 because the heating timer on the front of the boiler stopped working:
https://www.krieger-therm.ch/downloads/bht-002-with-wifi.pdf
My boiler connections look like this:
Do I connect the dry contact (1+2) from the thermostat to RT?
I’m afraid mate you shouldn’t even have the case off if you are not gas safe as it forms a combustion seal which needs to be tested to ensure that it’s replaced safely. You need a gas safe engineer in
Reply to Vaillant Ecotec Pro 28 + WiFi Thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached...
Sebastian T
