Discuss Vaillant Turbomax Main Heat Exchanger Leaking at Connection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jdstratton@btin
I have a Vaillant Turbomax 828E which has developed a leak at the Main Heat Exchanger Tube connection point.
Question if anyone can help : Is it normally just the packing ring which has failed or could it be wear / corrosion in the Heat Exchanger Metal ?
Your help is much appreciated .
Just to advise it was the packing ring that had deteriorated causing the leak .
Reply to Vaillant Turbomax Main Heat Exchanger Leaking at Connection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
