Discuss Valiant Eco turbo combi how to refill? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kiwikent
Hi I want to drain the system to move a radiator. We have not longed moved in so inherited this boiler, our last one was wasy to fill, there was a flex loop In image.jpg etween two valves. There doesn't seem to be a loop on this one and just wondering if anyone can identify which two valves I need to use to refill. Thank you in advance
There isn't a built in loop so trace the pipe work back and you should find one.
Very fiddily on those old vaillants, looks like yours has been leaking! Cut an external one in if it starts to play up!
Thanks gas safe , I was thinking that, the pressure gauge has packed up so was thinking of putting a loop in with a new gauge.....Do I put the loop between the "mains in" and the heating out or the return.....or does it not matter?
Any convenient point between cold feed and return flow. you might want to replace gauge on boiler at some stage so do it where you can see gauge. Don't forget the non return and rule about not leaving it in place.
Reply to Valiant Eco turbo combi how to refill? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Just had a "Main Eco Compact" combi boiler installed as the Biasi one failed. It seems to work fine, gives a hot bath, i dont ever use the...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
