M
Mondrota
Hi, I'm new to this forum so please bear with me.
I recently bought a house and have an old open vented system installed. The problem with it is that the boiler keeps overheating and shutting down for a while to cool down. I think it's due to poor circulation. The pump seems ok so I suspect there might be a blockage somewhere. While I was diagnosing the installation, i noticed that there is a valve connecting hot water flow just after pump to the return as in attached picture. Can someone explain what is its purpose? Also any tips regarding overheating problem would be much appreciated.
Forgot to mention that the installation upstairs is 15mm and 2 rads downstairs use 8mm microbore.
All of the rads barely get hot-ish when the heating is on. The boiler thermostat is on max, and boiler makes a "kettle - ing" noise.
Thank you.
Thank you.
