Discuss vinegar on stuck shower thermostatic valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
My customer has a two-knobbed shower (on/off, and temperature control). The temperature control has been siezed shut for about a year. I presume limescale - it's a hard water area, with limescale marks on the front of the shower.
I just looked up the price of thermostatic valves for Hudson Reed showers - they're so expensive.
In theory, a good soaking in a white vinegar/hot water solution might free up the thermostatic cartridge. Has anyone tried this in practise? Might it work, or is just too time consuming and fiddly?
Thanks again for your advice,
Jennie
Worth a shot but you may need to obtain a seal kit o rings and silicon grease try shower doc.com....regards Turnpin:punk:
Yeah you should be fine , briar an recommend doing the same on their cartridges if it hasn't been used for a while and doesn't work
price isnt your problem, it wont keep it going that long and youll be back idc to do it all over.
Reply to vinegar on stuck shower thermostatic valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am fitting a thermostatic shower control. The flow knob fitting has a threaded section - 27mm OD - and it would be helpful to get a nut to go on it. Can anyone advise what I need and where to get it please?
I'm attempting to replace an ultra SASF2 – M thermostatic shower cartridge but, having removed the temperature control knob from the housing that incorporates the temperature 'stop' mechanism, I cannot pull this housing free from the rest of the assembly. I can see no circlip holding it in...
Hi, I have a Aqualisa Midas thermostatic shower that has a very stiff temperature control. I have taken off the control knob and unscrewed the small cartridge screw with a hex key, but the cartridge is stuck fast inside the valve. I think it's a build up of limescale over several years and it...
1K
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was working fine for a coupe of months however now the valve has started misbehaving which is resulting in having to turn the temperature valve round further...
Hello. My mixer shower (non-electric) recently started running luke warm. I know this can happen at this time of year over winter but I've been in the property over 10 years and it's never been this bad before. The combi boiler was checked and is ok. The hot water from taps is uneffected and...
