Discuss Vitodens 100 WB1B - Hot water but no heat in the Central Heating Forum area at PlumbersForums.net
I have a 10-yr old Vitodens 100 WB1B. This fall a leak developed: the air separator located in the boiler above was leaking, and water dripped down and infiltrated the pump electrical housing in the Combi unit. This shorted out the Combi pump which then blew a fuse. I corrected the leak and dried out the pump and things worked again for the last few months. The other day the pump stopped working again and the fuse blew. I dismantled the pump and found that one of the pins that attaches the fine copper magnet wires had corroded and that's what was causing the fuse to blow. I hardwired the fine wire to the pump electrical housing pin (the one with the capacitor, etc.) and it seemed like problem solved. The motor spins, the fuse doesn't blow. I re-installed the pump, purged the system, tested hot water (works) put it into Service > Relay Test to check the heat to the radiator system was working (it did). But upon resetting the system the boiler comes on, cycles through the startup sequence, and then stops. Call to heat does nothing (no radiator icon just silence). Call for hot water does produce hot water (pump fires on, etc.) Service > Relay Test again fires up the boiler and heats up the radiant heat system until I exit service mode again.
I've checked the connections for the thermostat and they're secure. Thermostat is working correctly and calling for heat. I'm using an external temperature probe; outdoor temps are about 0 to -5C but I can't see as that could make a difference regardless.
Any suggestions? What am I missing? I've looked through the past 12 years of forum posts on the Vitodens 100 WB1B and can't find anything that addresses this issue.
Thanks in advance,
Tom
Canmore, Alberta
Canada
Reply to Vitodens 100 WB1B - Hot water but no heat in the Central Heating Forum area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
